- asebastianCommunity Manager
Hi Duncan,
It looks like you can install IIS on windows 10 home, take a look at this StackEchange post : https://superuser.com/questions/1245472/does-windows-10-home-edition-have-iis.
As far as a database is concerned, Jukka is correct. You can download the free version of MSSQL and connect your innovator instance to that.
AJ
- DuncanwilliamgibbonsCreator I
Thanks ill try that and get back to you
- jukkatlehtinenIdeator III
Aras is IIS application, so it needs Windows + IIS + SQL to run. BUT if you have Windows laptop, you usually can install IIS on that + free SQL Express (DB). So you don't need 'server' for that.
I'm not 100% sure which Windows versions support installing IIS (student?, home?, pro -yes).
Or are you using mac?
//Jukka
I have windows 10 home
- Former MemberNot applicable
I am trying to install ARAS on WIN 10 home, anyone succeeded yet??? i am using SQL EXPRESS , facing error W3SVC
- GopikrishnanAccelerator II
What is the error message ?
Im stuck on the aras innovator installer now, when i click configure database i get an error:
[Microsoft][ODBC SQL Server Driver][SQL Server] Login failed for user 'innovator'
Are you following the Installation guide which was packaged with the CD Image? Could you post a screenshot of the Installer before you press configure database?
Got it working by doing a fresh install, was probably an error with one of the password. thanks all for the help
