8 years agoAccelerator III
Hi Chris:
I tried your steps above and same error message. I use latest Google Chrome.
InnovatorSolutions
Resource with key="'login.login_btn_label'" is not found in "">localhost/.../ui_resources.xml".Resource with key="'login.cancel_btn_label'" is not found in "">localhost/.../ui_resources.xml".
Find the latest version of Aras Innovator
Resource with key="'login.version_html'" is not found in "">localhost/.../ui_resources.xml". 11.0 SP9; Resource with key="'login.build_html'" is not found in "">localhost/.../ui_resources.xml". 6549
