9 years ago
Installation role back after configuring database in windows server 2008
Sir, i am trying to install Aras innovator 11 on windows server 2008. After installing all the requisite software and doing all the necessary setting to windows server and sql server, i configured the database based on the installation guide and followed the videos of aras installation (www.youtube.com/watch. the installation roles back after a screen showing "creating application pool aras innovator AppPool ASP.net 4.o. I am attaching the screenshots of the errors occurred. Kindly give me a solution that would fix my issue. thank you https://drive.google.com/open?id=0B4doF9imyQA3a01tQW4wRlY2bGs drive.google.com/open
  • eli_donahue's avatar
    eli_donahue
    Hi sunilyrocks, Can you please confirm which service pack version of Aras you are trying to install? If you are installing the Aras 11 SP5 or newer, you will need a minimum of Windows Server 2008 R2, IIS 7.5, and .NET 4.5.2 on your server.
