Hello Carmenj,
The quick way to see if IIS was configured by the installer would be to open IIS up, then look under Sites->Default Web Site and look to see if your Aras Innovator instance is there. If it isn't, then something went amiss during the installation itself, and since you haven't started to use Aras Innovator yet I would suggest just uninstalling and beginning again, paying close attention to the names you set for the Web Alias and Server Name.
Skyler C.
- carmenj6 years agoIdeator I
The InnovatorServer is there under Default Web Site, with Client, ConversionServer, NotficationServer, OAuthServer, SelfServiceReporting, Server and Vault.
- Skyler_Crossman6 years agoCreator II
Carmenj,
The next question I have is whether you have the components of IIS installed. In your control panel, open the "Turn Windows Features On or Off" menu. (It's under Programs and Features.) You want your Internet Information Services section to look like the following:
Once you've done that, it may help to restart IIS- just open up a console and run "IISReset" there.
Skyler C.
Thank you, I am now able to access the login page!
However, now when I try to login, after a short while It says "The operation was canceled." I made sure to log in with the user name "innovator" and the password specified in the InnovatorServerConfig.xml file. Any idea what might be wrong?
