ncosta's avatar
ncosta
How to rename a database
Hi everyone,
I'd like to rename an Aras Innovator 12 database. I understand how to rename the SQL database. However, can someone please explain which Aras configuration files need to be updated to reflect this change?
  • asebastian's avatar
    asebastian
    Hi ncosta,
    You'll need to modify the innovatorServerConfig.xml file. There is a <db-connection> tag where you can adjust the name of your DB to match it's true name.
    AJ
