MaddyCreator II9 years agoHow to get File location to read the fileHi, I am trying to get the file location, the actual file is stored in vault, so how to get that physical path to read the file. Thanks, Maddy.
1 ReplyReplies sorted by Most LikedYoann_MaingonAccelerator I9 years agoYou shouldn't try to look for the location as we manage potentially replicated vaults, with a strategy to find the closest vault for each user. Instead you should use the API methods.
Recent DiscussionsAras PDF Viewer and Discussion ThreadWorkflow Continues after Lifecycle is CancelledSolvedInstallation issue : ODBC Driver 18 SSL Provider errorTrain and onboard a team on Aras InnovatorChanging File Type Column Width in Relationship GridSolved
