Duncanwilliamgibbons's avatar
Having troubles installing PE, CE and RE
Hi
I get an error when installing PE, CE and RE update packages. PE says its an incompatible innovator, but am using the latest versions
Thanks
  • asebastian's avatar
    asebastian
    Hi Duncan,
    Which version of innovator are you using, and which versions of the applications are you trying to install?
    AJ
        asebastian
        Hi Duncan,
        12.0 is only compatible with R1 of all the applications you've noted. If you'd like to use the latest versions of applications, you'll need to upgrade your environment to a more recent service pack.
        AJ
