asebastian
6 years agoCommunity Manager
Hi Duncan,
Which version of innovator are you using, and which versions of the applications are you trying to install?
AJ
Duncanwilliamgibbons
6 years agoCreator I
Hi AJ
Aras Innovator Version 12.0 Build: 13341
CE 12.0R2
PE 12.0R3
RE 12.0R3
- asebastian6 years agoCommunity Manager
Hi Duncan,
12.0 is only compatible with R1 of all the applications you've noted. If you'd like to use the latest versions of applications, you'll need to upgrade your environment to a more recent service pack.
AJ
- Duncanwilliamgibbons6 years agoCreator I
Thanks, tried installing the SP 8 but get a runtime error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed.
<!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="RemoteOnly"/> </system.web> </configuration>- Duncanwilliamgibbons6 years agoCreator I
Do I need to request a license key for the service pack too?
