Maddy's avatar
Maddy
9 years ago
Get Sever Error While running aras
Actually, my application run smoothly but I dont what changes I did to IIS Virtual directory so, It gives me Error like: Server Error in '/InnovatorServer/Client' Application.    Runtime Error Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed. Details: To enable the details of this specific error message to be viewable on the local server machine, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "RemoteOnly". To enable the details to be viewable on remote machines, please set "mode" to "Off". <!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="RemoteOnly"/> </system.web> </configuration> Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL. <!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="On" defaultRedirect="mycustompage.htm"/> </system.web> </configuration>   what should I do?
  • did you try what they tell you to do, so we can have an explicit error message ?
  • I tried what they say, Actually the extra space got added to InnovatorSeverConfig.xml file, so issue has been solved. and thanks for your reply.
