File checkout (using fetchFileProperty & checkout) not working in custom user with custom identity. how to checkout file in for user not having administrator permissions ?
I'm trying to checkout a file using item method fetchFileProperty in custom user with custom identity which do not have administrator permission.  Aras gets hang after this method call, also tried with file.checkout methods behaviour is same. With admin user file checkout with same code is working but not for different user.
What is the issue ? is this due to permissions ? what permissions needed to checkout file?
  • Hi Vaishalig,
    I would check two things:
    1. Have you given your custom identity access permissions for File?
    2. In the method you are writing, do you have "Execution allowed to" set to the custom identity and not administrators?
    Best,
    Nithin
