Nithin_Mahesh Can you please help me with this one.
- Nithin_Mahesh6 years agoCreator II
Hi Divyak02,
Is your index (solr and node clusters) installed in another machine and the agent in a separate machine? If this is the case it might be that the agent is failing since it cannot communicate with the index in the other machine and it could be related to firewall settings. Are you able to install the agent and file processor in the machine that has the index?
This is not an error I have seen before, let me know if this helps,
Nithin
- divyak026 years agoIdeator III
Hey, yes they both are in the same machine, I am just using the innovator instance on a different server. Previously the same configuration was working fine. Once I had deleted the ES Agent from the innovator and uninstalled the agent the while installing the agent service again the error came.
Is it related to deleting the agent from the innovator? May be after deleting the ES Agent from agents somewhere in background the clean up didn't happen.- Nithin_Mahesh6 years agoCreator II
Could be, you can check by going to the file location of the installs. If you used the default it would be in C:\Program Files (x86)\Aras\EnterpriseSearch. If there is a folder for the agent then it did not uninstall correctly previously and you should first uninstall again then delete the folder and reinstall.
