ES Agent Itemtype not found while installing ES Agent Service
Hey, I had installed solr, zookeeper agent and file processor services, firstly it was working fine with agents and crawlers being installed and working, then I had to use a different solr service for my instance so I uninstalled the agent service and reinstalled it again to use the new solr service instance but while installation the following issue saying no ES_Agent item type found. The instance used was same throughout the installation. After clicking OK on the below screen it was showing the installation is complete but agent was not getting installed and crawlers were also not present. Any inputs or suggestions would be appreciated. Thanks12KViews0likes8CommentsEnterprise Search problem: Unable to connect
Hi all, I'm quite new to Aras - installing it second time and this time around I'm installing it to the 2 servers so that the Enterprise search services are located in a another server. Briefly my configuration: App server: IIS with Aras Innovator SQL Express Searchserver: Solr, ES Agent & services Services: ES Agent ES File Processor Indexer ES Zookeeper I was trying to follow the installation guide. And everything seems quite ok: Aras basic functions are working properly Solr is answering nicely: from Search server http://localhost:8983/solr/ In Aras I can see ES Agent Crawlers (from toc/Enterprice search) ESFileCrawler, ESItemCrawler, ESPermissionCrawler, ESQueueCrawler, ESSolrCleanerCrawler And ESPermissionCrawler has processed some items Aras ES Agent 11.0, Aras ES File Processon 11.0, Aras ES Index 11.0, Aras ES ZooKeeper 11.0 Services are running in a 'search' server. So for me this looks like Aras and the search can communicate with each others. Servers should be in same network and powershell/Test-NetConnection tests gives positive results. BUT When I go to Aras TOC/My Innovator/Search/search form and click 'Run search' I'm getting: "Unable to connect to the remote server". Any help on this? How could I try to pinpoint the problem? How does the 'search' information is sent to the Solr? Can I make the search somehow from the searchserver directly (to check search is giving results back / rule in/out the network issues)? Any other tips to check functionalities of the Enterprise Search? Br, Jukka.2KViews1like0Comments
