9 years ago
Error 1720 just when installation is about to complete
Hi, I am Nikhil. While installing Aras innovator 11 server, I am facing a problem just at the end when I am about to finish the installation. I am getting Error 1720 which says "There is a problem with this windows installer package......". I have checked on the internet and I am using the latest windows installer version V5.0. I am meeting all other requirements for the server as mentioned in installation manual. I would be grateful if I can get a solution to this. I have tried twice and failed at the same point. Regards Nikhil
  • eli_donahue's avatar
    eli_donahue
    Hi Nikhil, Can you confirm that you have admin priviliges on the server you're installing to? Also, where is the installer msi located on the server? Eli
    • Rupesh_Pawar's avatar
      Rupesh_Pawar
      Hello Eli,
      I'm facing same issue.
      I already have administrator rights.
      msi installer file is located in downloads folder.
      regards,
      Rupesh
  • I'm having the exact same issue. I have admin privilege and the msi is located in my downloads folder (just tried putting in directly into C:\ and I got error 1303 admin privilege) Error 1720. There is a problem with this Windows Installer package. A script required for this install to complete could not be run. Contact your support personnel or package vendor. Custom action ConfigureWindowsAuthenticationSettings script error -2146827864, Microsoft VBScript runtime error: Object required: 'WScript' Line 18, Column 3, Thanks, Josh
