9 years ago
Difficulty installing Aras 11.0 SP5
Hello I have installed Aras 11.0 SP5 2 times :-( Windows 10 - SQL Server Express 14 - IIS 10 The installation went smoothly. Using the utility: sdns.exe - Result: [--------------------------------------------------------] Create new group with name "">ArasInnovator/InnovatorServer" ... [--------------------------------------------------------] Microsoft (R) .NET Framework CasPol 2.0.50727.8745 Copyright (c) Microsoft Corporation. Tous droits r‚serv‚s. Ajout de groupe de codes d'union avec la condition d'appartenance "-url" au niveau Machine. Op‚ration r‚ussie The SQL database and the server are executed correctly. When I run Chrome: You are currently running browser "Chrome 54". The browser has failed the browser requirement check. Please contact your system administrator to confirm your client against the platform requirements. When I run IE 10, here's the message: You are currently running browser "Microsoft Edge 14". The browser has failed the browser requirement check. Please contact your system administrator to confirm your client against the platform requirements. Thank you for your help Emmanuel
  • eli_donahue's avatar
    eli_donahue
    Hi Emmanuel, Are you navigating to your Aras instance via a desktop shortcut? It's possible that the client machine is defaulting to the MS Edge browser instead of using IE. Do you still experience the error if you open up a new IE window and manually enter your Aras url? If you are having trouble logging into Aras with Internet Explorer you can give Firefox 38 ESR a try: ftp.mozilla.org/.../ Note: Aras 11.0 SP5 does not support Chrome as a browser. Chrome support was introduced in Aras 11.0 SP7 and will be included in the next open release. Eli
