Hi Mark,
do you use the 'same' installer? Have you tried to use a fresh downloaded or copied version of the installer? It´s probably a registry problem. Maybe copy the copied installer to another folder location, then run the guid thing and try install again.
Most of the time, maybe already a second data base does the job. At least when you don´t do a lot of codetree development.
- MarkNorrisSDM4 years agoIdeator III
Hi Angelalp
I used the new installer which bizzarely took me to the old instance
in fact the root problem is errors in .net and iis so the aras application never got the chance to run
thanks for the input
Hi Mark,
do you get an error message?
I looked at the windows server console and everything is erroring! its a wall of errors there is corruption of dotnet.exe and KERNELBASE.dll
