Rim
5 months agoIdeator I
Aras Innovator 2025 Installation Error - HTTP 500 on IIS
I am trying to install Aras Innovator 2025 on Windows 10 with the following configuration:
- SQL Server 2022 Express (HOURANI\TEW_SQLEXPRESS)
- IIS 10
- ASP.NET 4.8
The installation wizard completed successfully, but when I try to access the application at http://localhost/InnovatorServer/Client/index.aspx I get HTTP Error 500.
What I have done so far:
- SQL Server authentication is enabled
- Database InnovatorSolutions created successfully
- Users innovator and innovator_regular created with correct permissions
- InnovatorServer application added manually in IIS
- ASP.NET 4.8 enabled in Windows Features
- ASP.NET Core Hosting Bundle installed
Question: What could cause HTTP 500 after a successful installation? Is there a specific IIS configuration needed for Aras Innovator 2025?
Thank you!
