Super's avatar
Super
Workflow haven't restarted after new manual revision
Hello, Gone through community posts but could not found answer. Hope some one could answer my question. Workflow is not restarted after creating revision to an item(Custom item type),  Does Aras restrict such restart of workflow? if yes, how could i achieve this. This is part of my data migration requirement where the newly migrated items needs to be in "Released" state and should be capable enough to revisioned and behave as normal workflow to vote.
  • Suhas's avatar
    Suhas
    Creator III
    Is ItemType  versionable? and Is workflow is set as default?
  • Hello,
    Please check if itemtype is set as versionable.
    If yes, attach workflow in your custom item type but don't set it as default, instead attach workflow on first activity of lifecycle. So once you revise your migrated item from released state. Lifecycle will re-start as well as workflow.
