9 years ago
webservice configuration
hi everyone, I have installed Aras 11 SP5 when I try to create a webservice configuration I get the following error message Event handler failed with message: TypeError: window.parent.frames.tearoff_menu is undefined [function onformpopulated$user$handler(e) { try { if (onformpopulated1(e) === false) return false; } catch (exp) { aras.AlertError(aras.getResource('', 'ui_methods_ex.event_handler_failed'), aras.getResource('', 'ui_methods_ex.event_handler_failure_msg', exp.description ? exp.description : (exp + ' [' +arguments.callee.toString()+ ']')), aras.getResource('','common.client_side_err')); return false; } }] Any idea ? thanks in advance! Luigi
  • eli_donahue's avatar
    eli_donahue
    Hi Luigi, It looks like the form itself is throwing a pretty generic client-side error. I would recommend contacting Aras Support for a fix and/or more information on configuring a web service. Eli
  • Hi Luigi, Have you solved the issue? I am having Aras Innovator 11 SP5 too, when I try to create a Web Service Configuration item, I got "Event handler failed with message: Object does not support property or method 'InnovatorServerConnector'". My understanding is that Aras 11 has removed the support of creating Web Service Configuration. Don't know why and can't find any example to publish a soap webservice for Aras.
  • no htz, no news... I hope in SP9 but I can't try it now.. But keep in touch, you never know. Luigi
