Hi Konrad,
I use a custom structure as replacement for the original PE structure query.
In my case I improved the filtering by adding an additional level for the Parent Part inside the query definition. When you normally create a simple multi-level BOM overview, you add Part and BOM use the "reuse definition" (?) setting. Then you can add an additional Part/BOM combination above this repeating structure. This allows you to just apply the filter on the repeating structure.
It´s not the perfect solution, but hope it helps.
Is it possible for you to show a sturcture of the query definition of the solution? I tried to recreate this but no luck.
I currently use something like this:
Note the position of the filter and "repeat query" setting.
But I have to admit, that the current solution is not used a lot by users. In our Innovator version, filtering isn´t a very popular feature yet, cause it only hides the text of the elements, but not the elements itself.
When I need more specific tree-views for the end user, I often create custom trees with a custom tree engine and don´t reuse the Aras Query Definition.
