shwnhlgn's avatar
shwnhlgn
9 years ago
"Success" Message after Starting Workflow
Have a C# method in an action that is initiating a workflow. Is there a way to have a message box pop up that tells the user the workflow was successfully started. Having issues trying to figure this out
  • You won't be able to create a message from the server side method, but if you are running this method in an action, you can set an "On Complete" method which can check if everything worked right, and then show a success message.
    aras.AlertSuccess("Workflow started correctly !!!");
