Yoann_Maingon
9 years agoAccelerator I
You won't be able to create a message from the server side method, but if you are running this method in an action, you can set an "On Complete" method which can check if everything worked right, and then show a success message.
aras.AlertSuccess("Workflow started correctly !!!");
