8 years agoCommunity Manager
There does not appear to be an easy way to change the sort order of this properties dropdown. Additionally, changing the sort order to "label" will not solve the issue of the entries not being listed in alphabetical order if there are any properties that do not have a label.
It is possible to create your own custom search mode. You can look at this Community Project for an example of how to accomplish this.
It may be possible to copy all of the code from the Advanced Search Mode into a custom search mode and make edits in the copy to manually sort all of the properties before the dropdown is populated. However, I don't have any samples of how this would be done. I would recommend naming this copy such that it is distinct and obviously different from the normal Advanced Search Mode.
______________________________
