jh's avatar
jh
8 months ago
setAction and apply does not work
this is my code
cjitem.setAction("delete");
cjitem.apply();
runing the code  it does not work,but I click Checking syntax button showing: Warning Number: IA1100, The output value of Item.apply() method is unused.
can anyone help me? thanks
  • cjitem.setAction("delete");
    sets the action on the object.
    cjitem.apply();
    does not mutate the state of the object, instead it returns a new object.
    You need to do:
    var newItem = cjitem.apply();
    the return value will be the result of your above action.
    You can then check the return value for errors or do some business logic.
