Nathan's avatar
Nathan
Creator III
Report to Find Items w/ Null Relationship
Good day all.  I am having a hard time trying to create a report to find Documents without files attached.  This is the current config. Aras v11 SP10 s_Document - Poly Source for the following It...
  • Nathan's avatar
    Well, I got this to work.  I can spit out a report with the information that I am looking for.  I have a small script in a Method & the Report uses the Stylesheet to make it look pretty.  I'm sure there is a bit more that can be stripped out of the Stylesheet, I just haven't played with it.
    My next step is to figure out how I can include the number of items searched through & the number returned so I can give a percentage.
    Method
    Innovator myInnovator = this.getInnovator();
    Item results = myInnovator.applySQL(
    "select item_number,cage,state,major_rev " +
    "from [s_Delivered_Document]" + "where id not in (select source_id from s_Delivered_Document_File) and is_current=1" +
    "order by item_number,cage");
    return results;
    Report Stylesheet
    <xsl:stylesheet version="1.0" xmlns:xsl="">www.w3.org/.../Transform" xmlns:msxsl="urn:schemas-microsoft-com:xslt" xmlns:aras="">http://www.aras-corp.com">
                    <xsl:output method="html" omit-xml-declaration="yes" standalone="yes" indent="yes" cdata-section-elements="script msxsl:script"></xsl:output>
                    <xsl:template match="/">
                                    <html>
                                                    <head></head>
                                                    <style type="text/css" userData="Global">
        .cellSolidRightBottom {
        border-right:1px #000000 solid;
        border-bottom:1px #000000 solid;
        .cellSolidRight {
        .cellHeader {
        background-color:#CCCCCC;
        border-top:1px #000000 solid;
        padding:2px;
        text-align:center;
        text-transform:capitalize;
        text-align:center;
        font-family:helvetica;
        font-weight:bold;
        font-size:8pt;
                                                    </style>
                                                    <body topmargin="50" leftmargin="50">
        <table border="0" cellspacing="0" cellpadding="0" width="670">
        <tr>
        <td width="260"></td>
        <td width="130"></td>
        <tr valign="top">
        <td align="left" uniqueID="ms_id77" colspan="9">     </td>
        </tr>
        </tr>
        <tr valign="bottom">
        <td style="font-family:helvetica;font-size:15pt;color:#DA1943;padding:2px;" align="left" uniqueID="ms_id79">Manuals Without Attachments</td>
        </tr>
        <td colspan="0" style="font-family:helvetica;font-size:10pt;padding:2px;" align="left" uniqueID="ms_id80">
        Generated on:
        <base id="ms_id81"/>
        <script> var d = new Date(); var months = ["January","February","March","April","May","June","July","August","September","October","November","December"]; document.getElementById("ms_id81").innerHTML = d.getDate()+" "+months[d.getMonth()]+" "+d.getFullYear(); </script>
        </td>
        </tr>
        <tr>
        <td class="cellHeader" style="border-left:1px #000000 solid;">Document</td>
        <td class="cellHeader">CAGE</td>
        <td class="cellHeader">State</td>
        <td class="cellHeader">Revision</td>
        </tr>
        <xsl:apply-templates mode="ORPH" select="//Item">   </xsl:apply-templates>
        </table>
                                                    </body>
                                                    <script src="../../javascript/PopupMenu.js"></script>
                                    </html>
                    </xsl:template>
                    <xsl:template mode="ORPH" match="//Item">
                                    <tr>
                                                    <td class="cellSolidRightBottom" style="border-left:1px #000000 solid; font-family:helvetica; font-size:8pt; padding:2px;">
        <xsl:value-of select="item_number"></xsl:value-of>
        <xsl:if test="item_number='' or not(item_number)">
        <xsl:text>Â </xsl:text>
        </xsl:if>
                                                    </td>
                                                    <td class="cellSolidRightBottom" style="font-family:helvetica; font-size:8pt; padding:2px;">
        <xsl:value-of select="cage"></xsl:value-of>
        <xsl:if test="cage='' or not(cage)">
        </xsl:if>
                                                    </td>
        <xsl:value-of select="state"></xsl:value-of>
        <xsl:if test="state='' or not(state)">
        </xsl:if>
                                                    </td>
        <xsl:value-of select="major_rev"></xsl:value-of>
        <xsl:if test="major_rev='' or not(major_rev)">
        </xsl:if>
                                                    </td>
                                    </tr>
                    </xsl:template>
    </xsl:stylesheet>
