C# SQL Date Query
Good day all, I am trying to create a dynamic report to produce the time it take between starting an activity and ending an activity. I can get the information I am looking for by using SQL, but it will not limit the returns based on dates. I have tried a few different ways to do this, but nothing is working for me. Thanks for any help you can provide. StringBuilder sql = new StringBuilder(); sql.AppendLine( "Select " + "WP.name AS change, " + "WP.state AS status, " + "Act.name AS activity, " + "ClosedBy.keyed_name AS closed_by, " + "Act_Assign.created_on, " + "Act_Assign.closed_on, " + "Act_Assign.modified_on, " + "GETDATE() AS today, " + "DATEDIFF (d, [Act_Assign].created_on, [Act_Assign].closed_on) + 1 AS date_diff " + "FROM [Workflow_Process] AS WP " + "INNER JOIN [Workflow_Process_Activity] AS WPA ON WPA.source_id = WP.id " + "INNER JOIN [Activity] AS Act ON Act.id = WPA.related_id " + "INNER JOIN [Activity_Assignment] AS Act_Assign ON Act_Assign.source_id = Act.id " + "INNER JOIN [sm_Change] as Change ON Change.item_number = WP.name " + "LEFT OUTER JOIN [User] AS ClosedBy ON ClosedBy.id = Act_Assign.closed_by " + "WHERE WP.name = 'CR-1091' OR WP.name = 'CR-1169' " + // AND Act.name = 'ECR Approval' "AND Act_Assign.modified_on BETWEEN '2023-08-01' AND '2023-08-02' " + "ORDER BY WP.name, Act_Assign.created_on ASC, Act_Assign.closed_on DESC " );Solved325Views0likes7CommentsHow to avoid the additional helper window when creating a report?
Hi, this is not really an urgent topic, but it´s something I wanted to ask for an eternity. When we create a new Report (e.g. Multilevel BOM Report), we will always get an additional empty tab that works as helper window. User have to close the window to work with Innovator again. But espcially new users often forget to close it and than are confused why they cannot use their Innovator any more. Is it somehow possible to avoid the helper window? Or automatically close it after the report was generated? Thanks! AngelaSolved6KViews0likes5CommentsDefine context item for query called via method
Hi, I am referencing this blog post: https://community.aras.com/b/english/posts/using-query-definitions-method-code I am running a query via method, how can I set the condition as the query seems to return all possible results without a context item.1.1KViews0likes1CommentSQL Server Reporting Services (SSRS) via HTTPS in Innovator Release 2023. How to fix?
Hi community, the release notes of Innovator 26 mentions following fixed issue: I-050277 Fixed an error that prevented Aras Innovator from connecting to SQL Server Reporting Services via HTTPS. I did a quick test in Release 2023 and noticed that I cannot create SSRS reports via HTTPS in this release. When executing the Report, I get following error message: "The provided URI scheme 'https' is invalid; expected 'http'. (Parameter 'via')". I assume Release 2023 still contains the bug that was patched with Innovator 26. Release 2023 removed the RSGateway.aspx that was previously used to connect to SSRS. Not sure how Aras calls the reports in the new versions. Does anyone know how to fix this one? I assume we need to customize the codetree, add some assembly binding or similar. But I have no idea so far how to do it. Thanks and best regards! Angela722Views0likes4CommentsRun Aras Report from Method
Good day all, How do I run an Aras report from a Method? I have several reports that I have created in Aras (not MS Report Services) and I can't figure out how to run one from a method. I'm trying to create a Modal Dialog so the use can pick the report and information needed, then run the report. I noticed that there is an applyMethod (and others), but it didn't seem to work when I tried applyReport (I was hoping it would be that simple). Thank you for any help you can provide.Solved2.7KViews0likes2CommentsContext from method to called email
I've got an email that I'm calling from a "post" method on the Part lifecycle, but the default context that's passed to that email message isn't the Part, it instead seems to be the alphabetically first Identity in my database? Why is this happening, and is it possible to (and how can I) pass the Part as the context item to the email, so I can use xpath variables for that part in the email? Alternatively, if there's a good way to just find the part that's being promoted via the email message query, that's fine too. That's the goal, however I need to get there. Here's the method that's running, for what it's worth: Innovator inn = this.getInnovator(); if (this.getProperty("classification", "") == "Hull Assembly") { Item checkIsRoot = this.newItem("Part BOM","get"); checkIsRoot.setAttribute("select","id"); checkIsRoot.setAttribute("maxRecords","1"); checkIsRoot.setProperty("related_id",this.getID()); checkIsRoot = checkIsRoot.apply(); if(checkIsRoot.isError()) { //First grab an identity to send the mail to. Item iden = inn.getItemById("Identity", "097FB092EBDE42EB9E5A274ABC0059DA"); //Next, grab the email we want Item myResult = inn.applyAML("<AML>"+ "<Item type='Email Message' action='get'>"+ "<name>BOM_Release</name>"+ "</Item></AML>"); Item myEmail = myResult.getItemByIndex(0); iden.email(myEmail, iden); } } return this;Solved3.1KViews0likes2CommentsReport Query Question
Good day all, I am trying to figure out why I can't a couple of reports to run. I know part of the problem is that our database does not use the OOTB Part ItemType. Our Parts List is a document ItemType and it links (weirdly) to our Part. I have this report that I don't understand what it is trying to do. Thanks for any help you can provide. Name: s_IPL Label: Indentured Parts List Type: Item Location: Service Target: Window Report Query: np:top_part_id=<xsl:value-of select="@id"/>&rs:Format=EXCELOPENXML7.4KViews0likes8CommentsReport - Method - Stylesheet Question
Aras 11 SP10 Good day all. I am trying to create a report that will pull all of the attached items from a document. I have a method that will get the information, but I can't get it to output correctly for the report (can't figure out the correct Stylesheet format). At the moment the method is referencing a single document by the ID number, but I will change this to cover a lot of the documents. I need a single line per related item, with the following fields (I will need to add more fields when this is working). Document ID Document Name Related ID Related Name When I run the report all of the related_id information is crammed into the Related ID cell. The Document ID cells will include the related_id number & the id number of the Relationship tab. Any help would be appreciated. Thank you. Stylesheet <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxsl="urn:schemas-microsoft-com:xslt" xmlns:aras="http://www.aras-corp.com"> <xsl:output method="html" omit-xml-declaration="yes" standalone="yes" indent="yes" cdata-section-elements="script msxsl:script"></xsl:output> <xsl:template match="/"> <html> <head></head> <style type="text/css" userData="Global"> .cellSolidRightBottom { border-right:1px #000000 solid; border-bottom:1px #000000 solid; } .cellSolidRight { border-right:1px #000000 solid; } .cellHeader { background-color:#CCCCCC; border-top:1px #000000 solid; border-right:1px #000000 solid; border-bottom:1px #000000 solid; padding:2px; text-align:center; text-transform:capitalize; text-align:center; font-family:helvetica; font-weight:bold; font-size:8pt; } </style> <body topmargin="50" leftmargin="50"> <table border="0" cellspacing="0" cellpadding="0" width="670"> <tr> <td width="260"></td> <td width="130"></td> <td width="130"></td> <td width="260"></td> <td width="130"></td> <td width="130"></td> <tr valign="top"> <td align="left" uniqueID="ms_id77" colspan="6"> </td> </tr> </tr> <tr valign="bottom"> <td colspan="6" style="font-family:helvetica;font-size:15pt;color:#DA1943;padding:2px;" align="left" uniqueID="ms_id79">Parts List BOM Info</td> </tr> <tr valign="bottom"> <td colspan="6" style="font-family:helvetica;font-size:10pt;padding:2px;" align="left" uniqueID="ms_id80"> Generated on: <base id="ms_id81"/> <script>var d = new Date(); var months = ["January","February","March","April","May","June","July","August","September","October","November","December"]; document.getElementById("ms_id81").innerHTML = d.getDate()+" "+months[d.getMonth()]+" "+d.getFullYear(); </script> </td> </tr> <tr> <td class="cellHeader" uniqueID="ms_id100" style="border-left:1px #000000 solid;">Parts List ID</td> <td class="cellHeader" uniqueID="ms_id101">Parts List Number</td> <td class="cellHeader" uniqueID="ms_id102">Parts List Name</td> <td class="cellHeader" uniqueID="ms_id103">Related ID</td> <td class="cellHeader" uniqueID="ms_id104">Related Number</td> <td class="cellHeader" uniqueID="ms_id105">Related Name</td> </tr> <xsl:apply-templates mode="ORPH" select="//Item"> </xsl:apply-templates> </table> </body> <script src="../../javascript/PopupMenu.js"></script> <script src="../../javascript/PopupMenu.js"></script> </html> </xsl:template> <xsl:template mode="ORPH" match="//Item"> <tr> <td class="cellSolidRightBottom" uniqueID="ms_id92" align="left" style="border-left:1px #000000 solid;"> <xsl:value-of select="id"></xsl:value-of> </td> <td class="cellSolidRightBottom" uniqueID="ms_id92" align="left" style="border-left:1px #000000 solid;"> <xsl:value-of select="item_number"></xsl:value-of> </td> <td class="cellSolidRightBottom" uniqueID="ms_id92" align="left" style="border-left:1px #000000 solid; word-wrap:break-word"> <xsl:value-of select="name"></xsl:value-of> </td> <td class="cellSolidRightBottom" uniqueID="ms_id92" align="left" style="border-left:1px #000000 solid;"> <xsl:value-of select="//related_id/Item[@id]"></xsl:value-of> </td> <td class="cellSolidRightBottom" uniqueID="ms_id92" align="left" style="border-left:1px #000000 solid;"> <xsl:value-of select="//related_id/Item[@item_number]"></xsl:value-of> </td> <td class="cellSolidRightBottom" uniqueID="ms_id92" align="left" style="border-left:1px #000000 solid;"> <xsl:value-of select="//related_id/Item[@id]"></xsl:value-of> </td> </tr> </xsl:template> </xsl:stylesheet>3.2KViews0likes2Comments
