- angelaCatalyst II
The filename column is never visible by default. It´s not a real bug. Innovator just doesn´t configure this very well.
You have to unhide the "related_id" property in order to see the filename. Take a look at other ItemTypes with the word "file" in it. This way you can just follow the existing samples.
- Nathan_H_Accelerator I
I had the same problem in the past. I figured out that the related_id was hidden, like AngelaIp stated. Another thing is to make the Sort Order 0 for the related_id so it will move to the front of the row.
