You might be able to do this by modifying the Stylesheet of the Multilevel BOM report. This stylesheet generates HTML based on the BOM structure passed into it, so you can likely add links <a href="LINK_TO_YOUR_ITEM"/> to the report.
Note that when modifying the stylesheet, you will need to click the Apply button at the bottom before saving the Report in order to keep your changes.
- jmadridIdeator I
Did not work, I got it to work another way though. Thanks for the help anyways!
Hi jmadrid,
If you're willing to share, would you mind posting the general approach for your solution here? :) I'd bet someone else will stumble upon this forum post in the future who's looking to do the same thing.
