Did not work, I got it to work another way though. Thanks for the help anyways!
Hi jmadrid,
If you're willing to share, would you mind posting the general approach for your solution here? :) I'd bet someone else will stumble upon this forum post in the future who's looking to do the same thing.
- jmadrid6 years agoIdeator I
Sure, its a bit complicated to explain but I'll do my best.
I implemented PLM's existing ability to create a link to an ItemType. For example in a part record, if you navigate to the top task-bar and select File > Properties > Copy Link. This is a shareable link that can be sent to someone that opens that ItemType in another PLM tab. For a part this link ends in:
/?StartItem=Part:2C04A166013F4A819CC2EA7C829DEC32.
Additionally, this link opens another browser tab to let the user know that the link worked, and that was messing things up in PLM. To overcome that, I created an iframe as such:
<iframe src="javascript.html" width="0" height="0" tabindex="-1" title="empty" class="hidden" name="iframe_Part"/>
Then I hid the iframe with the following CSS:
iframe.hidden {display:none}
To implement this in the stylesheet, I replaced the following line:
<xsl:value-of select="item_number"/>
With this <a> element:
<a href="URL_BEFORE_FORWARD_SLASH/?StartItem=Part:{id}" target="iframe_Part"> <xsl:value-of select="item_number"/></a>.
Just be cautious when using this link. If your hyperlink is a one derived from a part record, it will not open a CAD or Document, those have different links that look like the following, respectively:
URL_BEFORE_FORWARD_SLASH/?StartItem=CAD:{id}
URL_BEFORE_FORWARD_SLASH/?StartItem=Document:{id}
Also, I said URL_BEFORE_FORWARD_SLASH because this would vary from company to company.
I hope this helps. Thanks!
