Nathan_H_
5 years agoAccelerator I
ItemType Property implementation_ddl
Good day all. I was wondering what this property is used for, the Label is Definition. When I ran a Nash search to return this value, all of the ItemTypes were null. I would like to have a section for notes (or a definition) for the ItemTypes and thought that I could use this field. Thanks for the help.
Hi Nathan,
I assume this one is a legacy property that was never used. "ddl" is often used by Aras as abbreviation for dropdown lists. I assume it should do the same as implementation_type.
Aras will probably not remove it, cause it´s a core element. As it´s was never used in the past, I assume you´re free to use it for whatever you want. (*on your own risk)
