vriti_steepgraph_com's avatar
3 months ago
Inserting structured Requirement content via API in Aras RE (without UI editor)
I am working on Aras Innovator 28 with Requirements Engineering (RE).
I want to add content to a re_Requirement item programmatically (using AML / server method / API), instead of using the UI editor.By content, I specifically mean structured TDF content, such as:Text blocks, Lists, Tables, Graphics / Images, XML-based document structure used by the Requirement editor
Problem:
Direct AML with <content> XML does not reflect correctly in theeditor
The inserted XML is not interpreted properly by TDF
TDF ViewModel is not accessible from button click / client script
Sample AML:
<AML>
<Item type="re_Requirement" action="add">
<title>Test Requirement</title>
<classification>Requirement</classification>
<content> <![CDATA[ <Requirement xmlns="http://www.aras.com/REStandard" xmlns:aras="http://aras.com/ArasTechDoc">
<Text aras:id="1">
<aras:emph>Sample Text</aras:emph>
</Text>
<aras:table aras:id="2">
<Text aras:id="2">
<aras:emph>Cell 1</aras:emph>
</Text>
</aras:td>
</aras:tr>
</aras:table>
</Requirement> ]]></content>
</Item>
</AML>
Questions:
1. What is the correct way to insert structured TDF content (tables, lists, etc.) into re_Requirement via API?
2. Is there a supported way to access or reuse the TDF ViewModel / editor APIs from client-side code?
3. Should content always be generated using SchemaElementFactory instead of raw XML?
Additional Context:
I explored window.techDocContainer, Editor loading via LoadEditorTab event, AddElementAction.jsBut I could not reliably inject content into the editor.
Any guidance or working example would be very helpful.
christopher_gillis​ Gopikrishnan​
