how to retrieve checkbox value from form ?
hello,
i have a form that needs to get user inputs. On this form there are text fields, check boxes and a validate button that runs the logic to retrive the inputs. I'm able to retrieve the text fields with a method that runs on the click of the validate button.
the code that works for the text fields:
var tolerance = getFieldByName("tolerance").getElementsByTagName("input")[0].value;
but the value i get when i use this same code with a checkbox is always " on " no matter if i tic the checkbox or not.
thanks,
Lucas
Hi Lucas,
Can you try below code (replace bold letters with checkbox name)
var tolerance = document.querySelector('input[name="tolerance"]').checked;
alert(tolerance);
You will get true if it is checked, else false in alert
Thank You
Gopikrishnan R
