lucas's avatar
lucas
how to retrieve checkbox value from form ?
hello, i have a form that needs to get user inputs. On this form there are text fields, check boxes and a validate button that runs the logic to retrive the inputs. I'm able to retrieve the text fi...
  • Gopikrishnan's avatar
    Hi Lucas,
    Can you try below code (replace bold letters with checkbox name)
    var tolerance = document.querySelector('input[name="tolerance"]').checked;
    alert(tolerance);
    You will get true if it is checked, else false in alert
    Thank You
    Gopikrishnan R
