SowmyaK98's avatar
SowmyaK98
How to query Content Property in Technical Documentation
Hi Team,
Could you please explain how we can query 'Content' property in tp_Block itemtype.
As per my knowledge, all root and node elements along with id's will be wrapped up inside Content property/column in tp_Block table. If I have to find/fetch any id of certain elements like Title/Subtitle/Graphic, is there any way to achieve through Custom code? or should we have to write any SQL query in custom method.
Kindly help.
Thanks,
Sowmya
  • Hi Sowmya,
    it should be possible, but I haven´t seen a sample for this one yet. You can use a Method with an AML "get" query to get the "content" property of your tp_block item. With xpath you can then look for specific elements inside content.
    I made some tests for this one in the past to get content of text elements for translating the content into another language. I don´t have a ready to use sample, cause I mainly played around with an xpath tester.
    One thing that I remember: Sometimes the content property does not contain the content in a valid xml format. When your tp_block element for example just contains sections, there will no be any root element. So instead of making an xpath query on the content itself, better use the full tp_block item.
    • SmilingEel's avatar
      SmilingEel
      Thanks for the info i will try to figure it out for more.
    • SowmyaK98's avatar
      SowmyaK98
      Hi Angela,
      It would be great if you can share piece of code using XPath and querying Content elements. Sample piece of code.
      So that I also can try from my end and explore more on that.
      Thanks for your response.
      Thanks,
      Sowmya
      • SunilReddy's avatar
        SunilReddy
        Hi Sowmya,
        We can query any element inside content property through Xpath. We have already implemented in of our solution
