Hi Sowmya,
it should be possible, but I haven´t seen a sample for this one yet. You can use a Method with an AML "get" query to get the "content" property of your tp_block item. With xpath you can then look for specific elements inside content.
I made some tests for this one in the past to get content of text elements for translating the content into another language. I don´t have a ready to use sample, cause I mainly played around with an xpath tester.
One thing that I remember: Sometimes the content property does not contain the content in a valid xml format. When your tp_block element for example just contains sections, there will no be any root element. So instead of making an xpath query on the content itself, better use the full tp_block item.
- SmilingEel5 years agoIdeator I
Thanks for the info i will try to figure it out for more.
- SowmyaK985 years agoIdeator III
Hi Angela,
It would be great if you can share piece of code using XPath and querying Content elements. Sample piece of code.
So that I also can try from my end and explore more on that.
Thanks for your response.
Thanks,
Sowmya
- SunilReddy5 years agoCreator II
Hi Sowmya,
We can query any element inside content property through Xpath. We have already implemented in of our solution
Hi Sowmya,
are you an Aras partner / consultant or end user?
