harvey_str's avatar
harvey_str
Ideator II
How to display automatically properties from an ItemType in a Form from another ItemType, thanks to an ID
I'm searching for a solution capable of displaying automatically properties from an ItemType in a Form from another ItemType, with an ID that creates a link between them.
I have an item linked to a form and I have a second item with some properties. I want to populate one field of the first form with the data of the second item. This field corresponds to a certain property of the first item.
To highlight my problem there is an example.
The first Item is called “student_info”. . The other properties don't matter for my problem.
  1. ItemType, Name = “student_info”
1) "student_name", DataType = "Text",
2) "student_class", DataType = "String",
3) "exam_1", DataType = "String"
4) "exam_2", DataType = "String"
5) “id”, DataType = "Item", Data Source = "student_info".
In my form “student_info”, I have a field where I want to display all the exams that a student has passed.
All the exams infos come from the second item. This ItemType is called "exam". It has 5 importants  properties :
  1. ItemType, Name = “exam”
1) "exam_name", DataType = "String",
2) "exam_descrption", DataType = "String",
3) "exam_discipline", DataType = "List", Data Source = "Discipline",
4) "exam_monitor", DataType = "List", Data Source = "Monitor",
5) “id”, DataType = "Item", Data Source = "exams".
I succeeded in changing the “id” with the “exam_name” thanks to another question on this forum !
Each student has passed a different exam. And each exam can be passed by a different student.
So, in my “student_info” form, I have created a HTML Field with an id included in a div. The id is linked to a method called “load_exam” that displays all the exams the student has passed.
BUT for the moment, I need to add manually via a Relationship that I create between the ItemType “student_info” and the ItemType “exam”. To add the exam I need to go in the edit view of the ItemType “student_info” and in the tab called “Add Exam”. And after in a dialog box I choose the right exam.
Now I want to find a solution that automatically displays the list of exams for each student. In fact if I fill the properties “exam_1” and “exam_2” with the exam name, that corresponds exactly to the “exam_name” property. I want to have the list of exams in the HTML Field of the “student_info” Form.
Thanks for reading, I hope you can understand my problem and help me to solve it !
P.S. : I can show my JavaScript code for the method “load_exam”, if you want.
    • harvey_str's avatar
      harvey_str
      Ideator II
      Thanks Angelalp for you answer.
      But I already thought about nested forms and they don't match what I'm looking for ...
      More simply, I want to extract data from one or more Item from an ItemType (in my case, "exam") with the id of the Item I want. Then I want to display it in a HTML table in my "student_info" Form..
      The id is integrated in the form of "String" in my Form "student_info" but is not visible. Every "student_info" Forms have different "id" displayed as "String" so I should have as much data from "exam" in my table.
      I wish you can understand what I'm looking for.
      Thanks
        Hi Harvey,
        ah okay. I still do not fully understand your use case, but I see that nested forms are not the right solution for you.
        As far as I understand, you are already able to display content in your html element. So your onLoad Method basically works? But why do you want to connect with ids?
        Do you have a property in your "Exam" ItemType that contains the linked student? You could than make a simple get query with a filter for the student name and render the table in the html with the onLoad method.
        var exam = inn.newItem("Exam","get");
        exam .setProperty("student_name", "Kojak");
        exam .setAttribute("select","exam_name, result");
        exam = exam .apply();
        for (var i = 0; i < exam .getItemCount(); i++)
          // build table in html element
