Suhas's avatar
Suhas
Creator III
how to access a variable from the InnovatorServerConfig.xml file inside a c# method.
I need to get the value of ReportServer from the below configuration : <ReportingServices> <ReportServer>localhost/.../ReportServer> <User>XXX</User> <Password>XXX</Password> </Reporting...
    From my POV this one is one of the best customizations you can do cause it´s helps improving security. I once got this tip from another community member:
    XmlDocument xml = CCO.Cache.GetCacheInfo("ApplicationXML");
    string reportServerURL = xml.SelectSingleNode("//ReportingServices/ReportServer").InnerText;
    string reportUser = xml.SelectSingleNode("//ReportingServices/User").InnerText;
