angela's avatar
How can I set a NULL value with window.handleItemChange?
I am pretty sure this one is easy to solve, but I weren´t able to find a solution yet.
I have a Form with a regular standard button. When I click the button, Field values from a previous Item generation shall be mirrored into the current Form. Mirrowing regular values works fine, but I struggle to write NULL values into my form fields.
Here´s the sample of the code I use at the moment:
var previousValue = previousItem.getProperty("document_id");
if (typeof(previousValue ) !== "undefined" && previousValue !== null)
    window.handleItemChange("document_id", previousValue); // updates field to new value -> works
else
   window.handleItemChange("document_id", null); // <- update field to NULL -> doesn´t work
I tried this variant, but the database value will be an empty string and not a real NULL:
var previousValue = previousItem.getProperty("document_id",""); // <- database value will not be NULL!
window.handleItemChange("name", previousValue);
Thanks for any input!
  • Hi Angela,
    Could you confirm which version of Innovator you are using? I just ran a quick test in an 11.0 SP15 instance I have set up, and it seems that using handleItemChange with an empty string will set the value in the database to null in this version.
  • Hi Angela,
  • Hi Chris,
    Thanks for testing! I was pretty sure it did not work yesterday. Absolutly sure. But now it suddenly works also with my Innovator 11 SP11. The problem was probably my overengineered 'if' query, that I do not need at all. I like these mysterious problems that resolve themselves overnight.
  • I didn´t assue that this little issue would become so interesting.
    There is nothing wrong with window.handleItemChange.
    What I have seen yesterday seems to be some kind of regular text field behaviour, at least in my Innovator 11SP11.
    Once a text field contains a value, it can never be reset to zero. It can only be reset to an empty string.
    Steps to reproduce:
    1. Open an Item that contains a Form with regular fields
    2. Add a value into one of the string fields (e.g. name) and save the item
    3. Now delete the value from the text field and save again -> empty string instead of NULL will be set!
    This is no problem for my current use case, just was suprised about this behaviour.
    • christopher_gillis's avatar
      Ah! I was testing with an item field yesterday. I can confirm that in my 11.0 SP15 environment, using handleItemChange on a text field did not set the value back to null in the database. I checked our records, and it seems like this is filed to be changed but is not yet scheduled for a specific release.
        Good to know! Thanks for checking!
