7 years agoCatalyst II
How can I set a NULL value with window.handleItemChange?
I am pretty sure this one is easy to solve, but I weren´t able to find a solution yet.
I have a Form with a regular standard button. When I click the button, Field values from a previous Item...
- 7 years ago
Hi Angela,
Could you confirm which version of Innovator you are using? I just ran a quick test in an 11.0 SP15 instance I have set up, and it seems that using handleItemChange with an empty string will set the value in the database to null in this version.
