8 years agoCatalyst II
Hi Chris,
Thanks for the fast answer and the code sample! I didn´t know about the
FileContainerLocator. Finally I think I understand what the File_Handling.pdf provided in the Documentation folder want´s to tell me.
Now let´s see if I get things right:
1. Regular files referred to ECOs, Documents, etc. -> no container assigned
2. Regular files removed from ECOs, Documents -> Orphaned Files Container -> can be automatically deleted when using the Force.Delete.Orphaned.Files Variable
3. Thumbnails, Files created by conversion server or any other files without container -> Global Files Container
I wonder what´s the best way to clean up historic conversion server files? The files are easy to detect, as they all share a similar checkout path.
But I do not think it´s good idea to remove them automatically. Do you have any recommendations?
Right now the amount of Converser Server files is no problem, so this is more a question of "how to do things the correct way".
