Morgan's avatar
Morgan
4 years ago
Get parent of context item in relationship action
Hi all, I am using an action from a relationship grid which is driven by the PE_GetSelectedItems method. I need to get a handle on the parent item specifically as it looks like "this" returns a ...
  • alaxala's avatar
    alaxala
    4 years ago
    I found the problem. XmlNode.appendChild() moves the node, not copy. And next time the ccItem no longer has the property "source_id" and "source" becomes undefined.
    This is final version, I hope )). I also added a check for re-adding a "source_id" property.
    [embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:43a6d70b-e096-4c95-86b8-eff0e132cebe:type=javascript&text=if%20%28ccItem%29%20%7B%0D%0A%09var%20source%20%3D%20ccItem.selectSingleNode%28%22source_id%22%29.cloneNode%28true%29%3B%0D%0A%09ccItem%20%3D%20aras.getRelatedItem%28ccItem%29%3B%0D%0A%09if%20%28%21ccItem.selectSingleNode%28%22source_id%22%29%29%20ccItem.appendChild%28source%29%3B%0D%0A%7D%0D%0A]
    If you use item.getProperty you get the string with parent item id. If you use getPropertyItem you get parent item. But with only "type", "keyed_name" attributes and "id" property. It will not have any more properties since they were not in the original "source_id" property.
