Nathan_H_
5 years agoAccelerator I
Form - Field Label - Font Family - Change Default
Good day all. Does anyone know where I have to go to change the default Font Family? Currently it is set to tahoma, arial, helvetica, sans-serif. I would like to remove tahoma or move it to the back of the list. Thank you.
Hi Nathan,
oh I cannot count how often i replaced 'Tahoma' manually with a more up-to-date font. In Innovator 12 Aras itself finally had mercy and at least removed it by default.
You should be able do this customization in the FormTool/fieldTools.html in the codetree.
Did you clear your cache?
