Nathan_H_'s avatar
Nathan_H_
Accelerator I
Form - Field Label - Font Family - Change Default
Good day all.  Does anyone know where I have to go to change the default Font Family?  Currently it is set to tahoma, arial, helvetica, sans-serif.  I would like to remove tahoma or move it to the ba...
    4 years ago
    Hi Nathan,
    oh I cannot count how often i replaced 'Tahoma' manually with a more up-to-date font. In Innovator 12 Aras itself finally had mercy and at least removed it by default.
    You should be able do this customization in the FormTool/fieldTools.html in the codetree.
    4 years ago
    Did you clear your cache?
