Tks for all, I found the route issue cause, in my case my certificates are out of date, and I fixed it by regenerating new certificates following the topic www.aras.com/.../8428
Hi Helio,
glad to hear you found this solution! I am pretty sure we will see your question multiple times this year! (you just had the bad luck to be the first affected person).
Expired certificates where a huge topic two years ago. Cause at this time the typical I12 user used Innovator for two years.
Now again 2 years have past, and the same certificates will expire again. I will also be affected in a few weeks, but luckily already have the topic in my maintenance plan.
Be prepared for 2026 where people will ask the same question again! [emoticon:44a8a53ad3364ea78a16c5a3229f75bb]
P.S. I will copy&paste my warning from the previous post (something that Aras should do, but I assume they enjoy the chaos this topic creates on a regular basis):
IMPORTANT: For anyone who came across this post by accident: If you use the same Innovator 12+,14+ or Release 2023 instance for around 2 years, check the validity of your certificates. You might be affected by the topic of this post too.
