Suhas
6 years agoCreator III
Calling server method from another server method
Hello All,
From one server method (Method A ), I'm calling another server method (Method B) .
From (Method B) returning inn.newError("Error");
And in calling method (Method A) checking resu...
- 6 years ago
Hi Suhas,
see my reply below. You can pass any information from Method A to Method B by setting properties on the item you apply the method on:
// we have an Innovator object called inn
var methodItem = inn.newItem("Method");
methodItem.setProperty("some_info_for_method_b", "value for that info");
var resultItem = methodItem.apply("Method B");
You can then access some_info_for_method_b in Method B with
string info = this.getProperty("some_info_for_method_b", "")Of course, you can set as many of those auxiliary properties as you like, or pass all method arguments in one property, separated by commas.
Hope this helps,
C
