salini_sivasubramanian
11 months agoCreator I
ARAS31 import.mf deployment issue
Hai, We recently upgraded our environment from Aras Innovator 11 to Aras Innovator 31, and we are running into several issues while deploying our solution packages. I wanted to share the details ...
- 10 months ago
Hai MaksymArchybasov,
Yes, the error mentioned was that the system could not execute a bulk AML query. As recommended during the ARAS upgrade, we plan to split the files to avoid this issue, since the connection timeout is set to 2 minutes. I have already started working on this approach. However, the challenge is that I have several large XML files, which makes this task quite complex. Thank you very much for your support throughout this discussion—it has been extremely helpful.Salini.
