salini_sivasubramanian's avatar
9 months ago
ARAS31 import.mf deployment issue
Hai,   We recently upgraded our environment from Aras Innovator 11 to Aras Innovator 31, and we are running into several issues while deploying our solution packages. I wanted to share the details ...
  • Hai MaksymArchybasov,
    Yes, the error mentioned was that the system could not execute a bulk AML query. As recommended during the ARAS upgrade, we plan to split the files to avoid this issue, since the connection timeout is set to 2 minutes. I have already started working on this approach. However, the challenge is that I have several large XML files, which makes this task quite complex. Thank you very much for your support throughout this discussion—it has been extremely helpful.
    Salini.
