Hi Robert,
Here are some common integration approaches for syncing Aras data with other systems like Salesforce or SAP:
1. View-Only Integration (Plugin Required)
This allows you to view external system data (like Salesforce) within Aras. However, it’s read-only—you can’t make updates or collaborate across systems, and changes don’t sync back automatically.
2. Manual or Ad-Hoc Sync
Some tools support manual syncs triggered from the Aras UI. This approach can disrupt workflows, since users need to remember to trigger the sync. If it's missed or delayed, data may fall out of sync—causing inconsistency and rework.
3. Automated, Bidirectional Sync
This setup enables real-time, automatic updates between Aras and systems like SAP, Jira, or Salesforce. No need for manual triggers—data stays aligned on both sides, supporting better collaboration and traceability.
If you're exploring automated sync options, platforms like OpsHub offer prebuilt connectors for 70+ systems (including Salesforce and SAP). The setup doesn’t require deep technical know-how, and syncs can be configured to run continuously in the background.
Hope it helps!
