Suhas's avatar
Suhas
Creator III
Aras 12 Export issue
In a C# method we  wrote code query which contains XML CDATA. when we are trying export method, method exported with additional CDATA
Aras method contains below code:
sb.Append("<Certificate_Number><![CDATA[").Append(item.getProperty("certificate_number","")).Append("]]></Certificate_Number>");
but when we trying to export file below code generated in exported XML file.
sb.Append("<Certificate_Number><![CDATA[").Append(item.getProperty("certificate_number","")).Append("]]]]><![CDATA[></Certificate_Number>");
extra CDATA is coming in code.
Regards,
Suhas
  • Your CDATA is escaped, cause the Innovator export package contains the Method code withing a CDATA tag already. You you successfully import this Method?
