- alaxalaCreator III
Try this
[embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:a5d03a87-715a-4a3b-8e76-2d2d1bb45907:type=xml&text=%3CItem%20action%3D%27get%27%20type%3D%27Document%27%20select%3D%27item_number%2Ckeyed_name%27%3E%0D%0A%20%20%3Cconfig_id%20condition%3D%27in%27%3Eselect%20CONFIG_ID%20from%20innovator.DOCUMENT%20where%20STATE%3D%27Released%27%20group%20by%20CONFIG_ID%20having%20COUNT%28%2A%29%3E1%3C%2Fconfig_id%3E%0D%0A%3C%2FItem%3E]
You need to temporary add the
<operating_parameter key="parse_item" value="false"/>
to InnovatorServerConfig.xml to disable the AML secutity restrictions on the "condition='in'" expression.
- dkinsleyCreator II
I get this error...
<SOAP-ENV:Body>
<faultcode>SOAP-ENV:Server.ItemAnalysisException</faultcode>
<faultstring><![CDATA[Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.
Details:
Incorrect value: "<config_id condition="in">select CONFIG_ID from innovator.DOCUMENT where STATE='Released' group by CONFIG_ID having COUNT(*)>1</config_id>". Incorrect value explanation: "select" forbidden in property condition.
]]></faultstring>
<detail>
<af:legacy_detail><![CDATA[Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.
Details:
]]></af:legacy_detail>
<af:exception message="Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.
Details:
Incorrect value: "<config_id condition="in">select CONFIG_ID from innovator.DOCUMENT where STATE='Released' group by CONFIG_ID having COUNT(*)&gt;1</config_id>". Incorrect value explanation: "select" forbidden in property condition.
" type="Aras.Server.Core.ItemAnalysisException" />
</detail>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>- alaxalaCreator III[quote userid="4653" url="~/f/development/55312/aml-script-to-check-for-two-or-more-released-revisions-of-the-same-document-number/10526"]Incorrect value explanation: "select" forbidden in property condition.
Add the
