I get this error...
<SOAP-ENV:Body>
<faultcode>SOAP-ENV:Server.ItemAnalysisException</faultcode>
<faultstring><![CDATA[Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.
Details:
Incorrect value: "<config_id condition="in">select CONFIG_ID from innovator.DOCUMENT where STATE='Released' group by CONFIG_ID having COUNT(*)>1</config_id>". Incorrect value explanation: "select" forbidden in property condition.
]]></faultstring>
<detail>
<af:legacy_detail><![CDATA[Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.
Details:
]]></af:legacy_detail>
<af:exception message="Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.
Details:
Incorrect value: "<config_id condition="in">select CONFIG_ID from innovator.DOCUMENT where STATE='Released' group by CONFIG_ID having COUNT(*)&gt;1</config_id>". Incorrect value explanation: "select" forbidden in property condition.
" type="Aras.Server.Core.ItemAnalysisException" />
</detail>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Add the
<operating_parameter key="parse_item" value="false"/>
to InnovatorServerConfig.xml
- dkinsley2 years agoCreator II
Sorry, I don't have access to the Innovator Server Configuration.
